Buddy
It's easy to get caught up in a 'savings' fixation which turns into the idea that you are actually making money. When in fact....buying a cheaper machine does not make you money....at best it only saves you money.
But when evaluating 'making money'....that is done using the machine you bought and making signs. Theretical you should be able to at least make a few thousand dollars per month if not per year with a plotter. Therein is the 'making money'.....NOT by saving a few hundred dollars or even a thousand dollars.
I've had that same fixation before. The feeling of not being able to afford to get into computerized sign business and wanting so bad to get in that you begin to look endlessly at "cheaper" methods to seemingly accomplish the same thing.
The problem is........you will never be accomplishing the same thing. If that were true.......we ALL would have cheap plotters, cheap computers, cheap vinyl, cheap help......and we'd be making money.
It's not like we all don't know about cheap plotters and where to buy one.
We recently bought an $8,000 plotter. Is that because we didn't know about Decay brand plotters ? Darn the luck...I wish somebody would have told us.
No....it's merely that we have learned. You 'make money' by making signs.....not by saving a few hundred dollars or even a few thousand.
The time spent in trying to "beat the system" could better be spent in learning new design software and soliciting new customers so you could be 'making money' instead of saving a buck.
