hey all, im a newbie at screenprinting. i do small runs of tshirts here and there for swap meet events now and again. i make my own frames from poplar, Diazio emulsion, and use a variety of mesh.
i recently screenprinted a 2 color job, white and yellow on black, Hanes 50 / 50. i print using water based materials due to my setup at home and conditions of space that i have to keep frames. i used Plastisol opaque white, and Speedball Process yellow for this print. i mixed the process yellow with some opaque white to strengthen the yellow, but i think thats where something went wrong.
for this print i flashed the white with a heat gun as i normally do, then apply the yellow in 2 coats, flashing the first, and the last coat. i then let the shirts dry for 24 hours. i do this normally with every project and the results work for me. after 24 hours i washed 1 to see whats up. all the yellow washed out, ALL of it, not even a hint that it was ever on the shirt..
i have 19 shirts left with this pending doom feeling that all the yellow will wash out. heres my quesion.... can i apply transparent base over the yellow, even by hand with a paint brush, and will it protect the yellow from washing out? does it act like a sealant, if not what should i use? how can i save these shirts?
any help would be great.. thanks.
