now my other roland is acting up
petepaz
not a good day
first my vp540 is printing a shadow (posted a thread earlier with no response as of yet)
and now my sp300v is not printing yellow
i put a new cartrigde in and did 2 powerfull cleanings
and still my test print comes out with little or no yellow
it actually looks like the magenta is running into the yellow
petepaz
pics didn't come out so great
apparently the batteries in my camera are going also and the flash didn't work
what a great day
(didn't want to print foul language)
ericmitchell29
check your yellow cartridge. You may have a magenta cartridge listed as yellow. This happened to a friend of mine.
I hope thats not the case. But gotta check it.
petepaz
thanks for the help folks
tech guy from sign supply was here today
(that's who we bought the machines from) and he got both of them working
needed a new pump and damper and he checked out my vp as well
295 labor 3 hours + parts
but we are up and running again
asd
when my printer was doing that the heads had to be replace it was like a 18 months ago
If you have a bad cap and one cartridge completely runs dry, at times this will allow the empty cartridge to siphon from the full cartridge.
Put in a new cartridge and cap, then use a syringe (or pwr clean) to pull fresh ink till you get the proper color back. I like to use the syringe method as this doesn't waste a lot ink like the pwr clean option. NOTE: If you see air bubbles in the syringe as you pull ink then you have an air leak someplace else, check the damper and ink line connections.
