Old Composer Import Issue...
Discussion in 'Gerber' started by TheSnowman, Sep 12, 2008.
  1. TheSnowman
    TheSnowman Major Contributor
    6,919
    41
    48
    Aug 28, 2007
    Indiana
    I have this stone age piece of trash computer that I still use daily because old customers want the same thing that the previous owner did like, 12 years ago. Whenever I export something from it, into Illustrator, I have to make it a compound path. When I do that, everything is fine, if I'm going to cut it out of vinyl, but my question is what if I want to print it. Here's what I'm talking about. I tried to add color to it, and it did this. Is there anyway around this so I can just easily change the colors?
    I just made everything red on here, here's the results.
  2. WhiskeyDreamer
    WhiskeyDreamer Professional Snow Ninja
    3,550
    80
    48
    Aug 6, 2007
    Riften
    double objects?? looks like some objects aren't combined....and the text that's all wacky...check your nodes....you might have something in there that you don't know about
  3. signmeup
    signmeup Major Contributor
    7,468
    13
    38
    May 5, 2005
    Canada
    Wow! That outside furnace would an attractive addition to any home.
  4. TheSnowman
    6,919
    41
    48
    Aug 28, 2007
    Indiana
    It's happenin' when I import to Illustrator. I guess I'll have to open up good ole Windows 95, and see if I can figure out what's going on in Composer.
  5. TheSnowman
    6,919
    41
    48
    Aug 28, 2007
    Indiana
    Around here...it almost is an outside upgrade.
  6. Fred Weiss
    Fred Weiss Merchant Member
    20,555
    413
    83
    Sep 11, 2003
    Olympia, WA
    If you're getting duplicate paths in Illustrator you may find these downloads in the premium section helpful.
  7. _SAi_
    _SAi_ Member
    39
    Regarding the filled-in combined shapes.... try going to the Attributes pane, and with the object(s) selected, click on the button where I have the green arrow pointing. That might do the trick.
