Corwin Steeves
Large format printer to the stars
Are you sure about that?
The reason why that was written by me was to show about standards of other industries to get the output they need. People were saying Illustrator .ai, .pdf, .esp files or whatever are no good with their RIP and printer. I use .pdf files and work in RGB with Photoshop and Illustrator and my RIP is Shiraz.Those parameters are all fine and good for magazine art.
10 foot wide inkjets are a different beast. We have to KNOW we can get good results with minimal press checks.
A lot of this dumbing down of graphic requirements is due to the fact that many prepress techs don't even know what to do with good files.
It's a fail in this industry, and it was brought about with the last recession when all of the receptionists and grunts turned into graphic professionals.
The issue I have, is that I cannot make up for inexperienced designers with a "catchall" set of rules and numbers.The reason why that was written by me was to show about standards of other industries to get the output they need. People were saying Illustrator .ai, .pdf, .esp files or whatever are no good with their RIP and printer. I use .pdf files and work in RGB with Photoshop and Illustrator and my RIP is Shiraz.
If someone does get files from other sources I would think they would have a readout for the "graphic professionals" to go by so they would not have so many complaints about it. But like you said a lot of receptionists and grunts have also bought printers and software and now think they know all the answers.
Yes! we all have that special easy button built in! LMAO!I rarely use anyone's artwork to output, so I do not have issues that you are describing. But, when I send files out to be reproduced I like to know what they need because I picture a robot with no mind of it's own, hooked to a printer producing it for me, so I follow the instructions to the T so as not to mess up the robot's functions it has to do to achieve the output.
So now that robot has a name, Andy_warp.
Are you sure about that?![]()
Photoshop 4 was when I got in. Running quark on a power pc Mac OS8.6. I've been a technician on inkjets and large format scanners. The tools that are out now are quite a bit better in my opinion. Really the first go to as a culprit for problems is your process. My print environment is in a dusty shop...so if I'm not cleaning constantly, none of it matters.RGB, CMYK, .ai, pdf, eps, Illustrator, Corel, blah blah
They all have their place, but I agree with bob.. it's not the tool as much as the skill.
I used to run a service bureau and worked with all of them. I started in Illustrator 88 and photoshop 2.0. Can't remember what version of Corel I started with - whatever was out when Illy 88 was out. There was no InDesign back then - you used Pagemaker or Quark. Next we'll be arguing mac vs pc.
I used to work in a very high-end printing environment. I studied color under Richard Habera who was one of the early pioneers of scanning and digital photo correction. That man could look at a picture and tell you exactly how to get the colors that were supposed to be there. CMYK is what you need to use for jobs going on a printing press or copier. That would be industry standard for the print industry. And I would agree that the Illy/Photoshop/InDesign is pretty standard for that bunch. But we work with different RIPs, different processes. Definitely RGB for sign work IMHO - although the trade-off for good blacks is crappy yellows. It seems to me a lot of sign people use Corel - I don't personally because I know Illustrator like the back of my hand - but ask Joe Diaz about Corel... I would argue that Corel is probably more industry standard for sign shops than Illustrator. InDesign has no place in signage. Period. It is a page layout program, not a design program no matter what Adobe would like to think.
But back to the original question. Profiling is probably a big part of the problem, but Rolands are notorious for the red tint in the neutral colors. Monitor calibration, color space and format may be part of your issues too. You may want to consider getting a pro in to do profiles if you aren't able to do yourself. Good luck!
That's where I would start Michele. Don't kill your media you are currently using, but try creating a new one and linearizing. You do need a densitometer or spectrophotometer to take readings. If you get good density ramps into the media profile it may balance things out. After that do some testing with grayscale photos and RGB photos that are desaturated (B & W, but in the rgb colorspace)Versaworks has basic media creation facilities, and can do channel limits/linearization and import ICCs (no internal ICC generation functionality).
Onyx 12.2 appears to open .AI files on our workstation, so yes.
I know Pauly is on 12.2 also.
Our ONYX (Thrive 12.2) doesn't show .ai files. I suppose you could change the extention and "trick" the RIP into opening it, but according to ONYX it's not a supported file type.
"While Adobe Illustrator (.ai) files will usually render correctly, they are not a supported file type. The .ai file type is a proprietary format owned by Adobe. If there are rendering problems, troubleshooting the issue is limited to RIP changes such as the Configure RIP Postscript options (Setup, Postscript, Configure RIP), and enabling or disabling CCADL and OVERPRINT. If an .ai file is not rendering correctly, the best option is to export the image as a PDF file ver 1.6 or later from Adobe Illustrator."
You can also type *.* In the file type box, and it should show all file types, even un supported ones.
