Small Vinyl Letters
Discussion in 'General Signmaking Topics' started by Dooka, Apr 10, 2013.
  1. Dooka
    Dooka New Member
    22
    Feb 10, 2013
    North Carolina
    So I'm having to weed some 1/2" tall letters.
    100 lines of it for some acrylic plaques.
    I am weeding with some intermediate vinyl.
    It is not going very well.
    Any suggestions, should I try some 3M high performance?
    I thought about applying to acrylic before weeding, but a little worried about handling the acrylic like that, dangerous to scratch.
    Thanks for everyones help!:help
  2. petepaz
    petepaz Major Contributor
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    apply the application tape then weed it off of the app-tape this way the letter doesn't move or come off.
  3. Malkin
    Malkin Very Active Member
    2,194
    26
    48
    Feb 11, 2009
    Augusta, ME
    3M's high performance ElectroCut vinyl works well for small stuff. It has the synthetic mylar backing.
  4. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    +3M with the clear plastic liner. 1/2" isn't that small, on the 3M it will weed like a dream.
  5. Z SIGNS
    Z SIGNS Very Active Member
    1,077
    149
    63
    Feb 14, 2009
    Trenton NJ
    print em on clear and forget about weeding.
  6. gabagoo
    gabagoo Major Contributor
    5,740
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    This!!! I am doing letters upper and lower case now 1/4" weeds perfectly. Only problem up here is that suppliers dont supply and it is a special order.
  7. Dakotagrafx
    Dakotagrafx Member
    182
    Jan 6, 2011
    Michigan
    properly set up cutter with sharp blade - 1/2" should be easy weeding. what plotter and blade are you using?
  8. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,847
    70
    48
    Feb 27, 2007
    World
    put it in the frezzer for a few minutes then weed it
  9. MakeMyGraphic
    MakeMyGraphic Member
    118
    Feb 21, 2012
    San Diego
    wow, does the font you chose have a ton of serifs??? I always avoid serifs like the plague when it comes to long drawn out die cut messages or just charge EXTRA for them if they are smaller than a certain size, but 1/2" shouldn't be a problem unless you have a ton of serifs as I was wondering....
  10. Patentagosse
    Patentagosse Active Member
    603
    19
    18
    Aug 17, 2011
    Joliette, Quebec (Canada)
    3M 7725 (ElectroCut serie) is a very good vinyl for small caracters.
    I do the "freezer" step which is also a great way to shrink the vinyl enought to get a nice white line around the letter. That works good with calendred.
    Plotter settings / blade sharpness are also mandatory.
  11. SignosaurusRex
    SignosaurusRex Major Contributor
    8,591
    511
    113
    Mar 7, 2007
    Washington State
    This Works
  12. OldPaint
    OldPaint Major Contributor
    calendered vinyl.........cut and let it set for 24 hours.......it will shrink enough to see a the white backing paper as a line))) or app tape it then weed from app tape.
  13. CentralSigns
    CentralSigns Very Active Member
    1,338
    Jan 23, 2010
    Golden BC
    use a real thin cast vinyl, always easier to weed. Worth the extra cost 10 x over
  14. DizzyMarkus
    DizzyMarkus Active Member
    822
    Issues with 1/4" not 1/2" -- check your settings and blade.
    Markus
