A while back I had used the infamous translucent white wiper blades and would get a grinding sound from them hitting the scraper. I had to live with it until I could get some black ones in. But I guess over time something has worn out as it is now even creating the grinding sound with the black wipers. Not sure if the gear is stripped on the motor or the screw has backed out (or even the motor has gotten week). But in any case the wipers currently won't go past the scraper so it looks like something needs replaced (I did replace the wipers and scrapers to eliminate that fix). I went ahead and ordered a motor, belt and gear to have before I tear everything apart. But...
- Anything I'm missing that could fix this (like a belt adjustment)?
- Any tips on getting to the motor? Quite buried in back so will require a lot of disassembly from what I can tell.
