AUTO-FX
in a typical urethane base coat/clear coat system ( Dupont, PPG ) , the metallic is in the base coat. in a custom job, it could be in the clear, but it wouldnt be in the final coat of clear or you would not be able to "color sand", polish, or buff it. I checked, and it is typically aluminum, although polyester may be used in some paints. So magnetism does not explain the migration of metal flake toward the surface, and it may not have been migration at all, it just appeared to be the case.
