Signmaker1234
Anyone know the temperature for heating oracal 751 to break the memory?
Thanks in advance!
Thanks in advance!
751 isn't a wrap material (unless they've changed it). You shouldn't need to be heating it at all.
Edit for clarification: Under normal circumstances, heating is not needed. 751 is normally for cut vinyl graphics. Yes, it can be heated a bit to cover rivets that might be under what you're laying, but it will not perform like a wrap film will.
I use 751 a lot and i also use a variable temp heat gun. I run mine at 250 which is the lowest temp it starts at but i keep it about 8 -10 inches away which brings it down to about 200* and it works perfect with a rivet brush or finger glove. Never had an issue .I've done the racing go-carts that have the wings on them that have rivots .....
.......According Per the Oracal spec sheets (or the Oracal USA app available for iPhone and Android), the temperature resistance of Oracal 651 film is -40° F through +176° F. Oracal 751 is rated up to 230° F - ditto for Oracal 951.
My heat gun is a wagner ht3500. i think i paid like 35 for it. works awesome... That info i posted Starting after " According" about the app etc was just copied from another site ,I just looked up what your question was about and found that info...
I use oracal 631,651,751 etc except my camo and carbon fiber is a different brand---
