The majority of your applications: Wet or Dry?
Discussion in 'Polls' started by darkdan, Nov 23, 2008.
Wet or Dry, DIYer or sign shop
  1. Full time sign shop: Majority Applied WET
    16 vote(s)
    9.5%
  2. Full time sign shop: Majority Applied DRY
    127 vote(s)
    75.6%
  3. DIYer: Majority Applied WET
    1 vote(s)
    0.6%
  4. DIYer: Majority Applied DRY
    24 vote(s)
    14.3%
  1. darkdan
    darkdan Member
    108
    Do you apply most of your vinyl wet or dry?
    This includes things like coroplast signs, vehicle lettering, banners, window apps, etc etc etc.
    Are you a full sign shop or a DIYer?
  2. Replicator
    Replicator Major Contributor
    10,230
    10
    38
    Nov 19, 2006
    Sun City, AZ
    D.r.y.!
  3. darkdan
    darkdan Member
    108
    That was a crazy fast reply man. Your post showed up as my browser refreshed from making a new post. At first I thought something was wrong. LOL.
  4. Replicator
    10,230
    10
    38
    Nov 19, 2006
    Sun City, AZ
    Like I said DRY . . . Like LIGHTNING !
  5. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Full time sign shop, I like to do stuff dry.
  6. Digitall
    Digitall Guest
    We always do dry, except for 1 27 foot backlit this month that was hard to hinge. Window perfs should never be done wet,in my opinion, moisture stays trapped. If you do wet and using soap and water type, try adding alittle winshield washer fluid to mix and it will dry much faster.
  7. signage
    signage Major Contributor
    10,606
    268
    83
    Oct 5, 2005
    Penn
    Dry
  8. TheSnowman
    TheSnowman Major Contributor
    6,919
    41
    48
    Aug 28, 2007
    Indiana
    I'll do them dry w/ the big squeegee. A couple times, I've had to do large graphics, and I couldn't get the squeegee in there because the frame was smaller than the squeegee, so those I did wet, and rolled out, but other than those instances (which aren't often) dry. Keeps the shop nicer too...
  9. cgsigns_jamie
    cgsigns_jamie Very Active Member
    Most everything Dry. The only time we install wet is if it's a huge graphic or if we are doing color inlays.
  10. THATgirl
    THATgirl Very Active Member
    2,942
    4
    Dry! ('cept if I am layering)
  11. SignTech
    SignTech Guest
    Dry
  12. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    dry,, but could be wet,,
  13. sarge
    sarge Active Member
    923
    dry unless layering
  14. Custom Signs
    Custom Signs Member
    471
    1
    18
    May 16, 2006
    Longview, TX
    Dry
  15. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,854
    74
    48
    Feb 27, 2007
    World
    Dry......unless my gf is around
  16. Craig Sjoquist
    Craig Sjoquist Major Contributor
    6,746
    4
    38
    Jun 18, 2004
    Orlando
    I like wet mainly because of options.. but it's really about 50/50
    since I don't have a plotter to cut .. very few jobs are in vinyl anyway, getting vinyl cut takes to long from design to ready to install ..
  17. jasonx
    jasonx Very Active Member
    1,319
    30
    48
    Aug 5, 2007
    Australia
    Only time we do it wet is when its raining outside :)
  18. Gino
    Gino Premium Subscriber
    33,946
    2,502
    113
    Jun 7, 2006
    PA
    I know..... this is a trick question........ :omg:
    We rub it three times before adding shaving cream to the formula. When removing the second step from the process we then layer for breathing room by throwing a little pachouli on the underside. After the lingering odors fade, we then run over to the mailbox and see if any yellow lunch buckets are in the taxi before returning in our snuggies. When all is clear, we set the fuse and start doing somethin'.... that's the frickin' step I keep forgetting. :frustrated:
    What do I win.... huh, huh ??
  19. ProWraps™
    ProWraps™ Guest
    a quick trip to the rubber room.
  20. Digitall
    Digitall Guest
    Great answer. got me laughin at 2:30. Needed it after reading undercut.com all night. $3 foot makes me realize i am being raped by 3m.
