UV 84DTS Direct Color System DCS 4x8 printer reviews
graphics22
Direct Color Systems released a 4x8 printer table in Oct 2020 which supposedly worked out a lot of the bugs that existed with the 7200z. Does anyone have direct experience with upgrading from a 7200z to the UV84DTS. Interested in the good, bad and ugly. Much thanks
OakhurstPrinter
I know it is typical form for people to post negative replies, but in the case of DCS and the 4x8 UV flatbed, it is all I have.
We purchased the UV-84DTS for the same reason it appeals to many that look into it. We wanted to produce more ADA signage, faster. By all regards, the DCS is like adding more hands to your ADA team. However, we were given a much different spec than what we have been able to output. Almost a year after we purchased the machine, we still haven't managed a full bed of braille and tactile (only; no flat print) still takes us over 3 hours to print. In a average 8-hour shift, you can send 2 full sheets of material, allowing for substrate changeover, alignment on table (no alignment pegs, have to use the engraved mm table guide) and the (IMO) ridiculous file setup process.
Let's start from the beginning. The provided Color Byte software is another facelift on the same old sign layout software. Lots of functionality that comes with no explanation. However, returning DCS customers will likely feel at home as I believe this is the same software used across their product line (I'm new to DCS products so please check into that if interested {lazy writing, I know...I'm sorry}). I'm not a fan of opening AI files in other vector layout software just so I can access the RIP. With Color Byte, I have been told there is no real option around it because of the braille and tactile building system). My process is now taking in-house built AI files, opening them in Color Byte, sending them to Color Byte RIP, which then RIPs to the DCS Control software. In all of those transitions, I can only hope that nothing in my files has changed and all will produce with the intended result...yikes.
Credit where credit is due, this product launched during a global pandemic. I don't think anyone was as ready as they thought. DCS support and techs have been patient (if not a bit overconfident sometimes) but have usually helped me get to my nearly-desired product. We have had 4 service visits, replaced 3 parts (only one of which was a "consumable") and still have a mountain of questions. Currently, it is mostly down due to calibration issues. In fair play to DCS, this one may have been User Error!
Now, the good news. 5 G5 heads, comparatively noiseless carriage motion, no capping station, no vacuums (except for the bed, of course) and a DAMN SMART white ink cycling system.
G5 heads produce beautiful images with controllable dot-gain and seemingly easier to maintain. We get fewer lost nozzles that our Mimaki, the ones we lose are reclaimed quickly with DCS' purge and wipe system. 5 heads with 7 head stations, including 2 CL heads for ADA builds, a 2-channel white head, YK, and CM.
The dual-vacuum bed fully encloses the vacuum motor, cutting the noise down drastically. However, check your acoustics before installing as we were overwhelmed by the sound when in a tight space with no carpet.
Ditching the capping station is an intriguing step. Automated maintenance is a wonderful feature when you have it, but I find manual cleaning is faster and allows for on-the-fly cleaning. I will say that the waste station "tray" feels like a last-minute thought. I mean, its just a large funnel with a hole and 12 inches of hose. Maybe it's a petty dig at DCS but, come one...I just put this carpet in.
Sorry, this is supposed to be the good part of the review.
Lastly, there are no SHOP VACS to replace like in the HP Scitex models. The white ink recovery/recycling system may or may not be an original concept (my first time working with it) but I'm happy to not have to shake another bottle/box/bag of white ink. The system has a supply pump, running through heater areas to keep the thick ink flowing as easy as it can. This ink cycles through small subtasks in the carriage head and then returning it to the main tank so as not to overcook the ink.
Bottom line, this is the first operating line for this product. As a rep from Cannon recently advised, wait for the 3rd generation. I think DCS will really have better understanding of the technology on a larger format.
I hope this helps. I have not written a review in a long time.
(My background: Sign building for 23 years; printing for 15 of those. The UV-84DTS is my first DCS experience.)
GaSouthpaw
DCS is garbage. I've posted previously about the flat out lies they threw out when a previous employer purchased one. I'd say wait until someone else actually makes the tech work correctly, because while the 4'x8' version of the printer might have "launched during a global pandemic," they released the original version of the product with an 11.7x23.7 bed something like 7 or 8 years ago, so it's not like they haven't had time to correct the problems. But, every problem Oakhurst posted above- and then some- were present then, too.
I would suggest looking into Mimaki- I'm pretty sure they have a printer that accomplishes the same thing. Even if you end up getting a smaller version, you'd still be better served than wasting your time and money fighting with DCS.
graphics22
Morning, looking for an update on the UV84DTS is it still runnings signs for you well. Would you be able to add an update for me. I have 2 - 2x4 tables 1 of which is inoperable, parts for these 3 year old machines are getting scarce. The epson capping station is discontinued so looking to make a move sooner than later
IndianaAve
I just spent three weeks in the print room working with the machine. I am not the operator, but here are my takeaways.
Look at other manufacturers.
When the machine works, it produces great product.
We are building a network of DCS users for mutual support. If you own the DTS84, drop us a note here and we will add you to the user group list.
The machine does not provide the throughput that was promised. Bottom line is that our current daily target is 4 x 4x8 print runs a day. The average time to run a 4x8 bed is 1.5 to 2.0 hours.
Maintain, maintain, maintain. Clean the heads before every print job, even it has only been idle for 15 or 20 minutes. Calibrate. Grease. Oil. Do everything you can to avoid needing DCS customer service. They are nice people but understaffed with weak support systems. For example, our machine stopped running recently. A service visit was a minimum one-month out. We replaced parts using phone support several times. The best we could achieve was one-direction printing. We ran 20+ calibrations one afternoon and the bi-directional printing restarted.
Turn the light intensity up.
Jig. Even for flat substrates. Reduce print time for paper masks, etc. Standardize everythign so those print heads are running finished product as much time as possible.
Think long and hard about adding ColorByte to your pre-press process. If you do go the DTS path, get a second copy so you can support the print room without having to take up the computer attached to the machine.
Anecdotally, we know of one other buyer who is moving away from DCS after 2 years. He has both the 4x8 and a smaller machine. Neither are performing.
MikeGPA
Hello all, first post here. I am currently running a UV-84 and like most experiencing some less than stellar support from the otherwise nice folks at DCS.
I am definitely into joining this group if possible. Thanks!
True
We just got a uv44 at my work. The latest from dcs, the ew 183 controller says the heating is on but it does not move temp from 30c even when its set to 40c. Anyone got a solition? It worked last week when they were here.
Best Signs
Good Morning All,
We have had this " Gen 1" DCS printer for about 5 years and there have been multiple issues in which we were able to overcome some of them and the latter we needed to contact customer support ( Which seems to take days)
At this moment we are thinking of moving to the GEN 2 version of the machine. Has anyone used the Gen 2 yet?
Brian Campbell
Production Manger - The Ohio State University
Good Morning All,
We are running a GEN2 UV84. Installed in January of this year. Love the machine. We have had the smaller MVP in the shop for about 8 years so I knew what to expect, or what not to expect, from DCS support. So far going good with one breakdown so far. The mixer pump in the white ink tank stopped working, and resulted in plugged ink head. Worked with DCS and we changed to a new style mixing motor. Much larger stepper motor with a blender like blade in the tank vs old small circulation pump. I feel really confident about that now. After several attempts to flush the white head we ended up needing to replace it. Not good needing a head only 6 months in, but DCS worked with us and made it right.
We run about 75% flat work and 25% ADA right now. Will be doing a ton more ADA soon. We are starting on an entire 26 floor hospital that needed around 25,000 ADA signs over the next 18 months. So it going to be a good test on how this device hold up.
AS for DCS as a company, we have leaned to work with them. Tech support is hard to get a hold of the right person at times, but once you do they resolved the issues quickly.
ThirdRockDesign
Had the 7200z as first DCS printer. Moved to the uv_84 Gen1. Would have gladly taken the 7200z back, even though they were discontinuing support for it, since the print quality on the UV84 was nowhere near what we had been used to. Had to constantly deal with calibrating heads which was never an issue on the 7200. Had only printed one or two jobs that required a full table so mostly small runs or I printed larger jobs in groups. I also never trusted the heads to produce crisp text that far across the bed without wanting to dry out and start spitting. Recently moved to the Gen2 and it's been problematic as well. White head is the problem so far and just after a couple months of use. Came in after a weekend and could barely get ink to purge through the nozzles when it had printed fine the Friday before. Had to pull head and soak overnight (2 times so far since it still has dropout no matter how much purging is done). It would print better after that or flushing the head but by next day was back to clogged nozzles. Just did an ink/filter replacement and still missing nozzles so soaking right now (3rd time). It's a completely new learning curve for print modes and there will most likely be a dozen or so options although you'll probably find yourself sticking with one for ADA and one for Standard. Where you typically had a buildup layer height of 3 clear and 3 white for ADA it will now be 8 clear and 5 white so there's some getting used to it. Some print modes produce horrible banding so no idea why they thought to include them. Colorbyte design and Rip screens haven't changed. Control has a similar look to it but task locations have changed some . Also, any custom colors you created in gen1 will all need to be redone with the Gen2 and I would recommend backing them up somewhere before your installer accidentally wipes them all :( You can use them as a starting point but color curves are different. Your 0/0 axis point is back to the front right of the machine like the 7200.
There are positives to the gen2. The ability to turn off specific ink channels when purging/troubleshooting so other inks are not wasted. Automated shut off on subtanks so no emptying after a power failure like the Gen1. Print quality seems improved over the gen1 heads. Pin registration is helpful for larger substrates and aligning to the table. You get the taller z-axis height back that you lost going from the 7200 to the gen1. It's 12" now vs. 4something". No more messing with plastic encoder strip. This one is magnetic. Overall it looks like they addressed a lot of the improvements needed over the Gen1. Service is still spotty. You could hear back quickly or it could be next day before you get a reply.
ThirdRockDesign
Did they replace the white head for free? We are in the same boat after only a few months and relatively little use of the machine. Came in after a weekend to find clogged nozzles and have now pulled and soaked 3 times as well as flushed at least 3 times and still can't recover head fully. I found out they are in the process of creating a cap to put flush in and attach under head so you don't have to pull it out which tells me this is a know and probably wide spread issue with white.
AncientOne
May I be added to this group?
ThirdRockDesign
Anyone running a uv84 Gen II notice that if you have a power flicker or power failure and the machine comes back on that the white ink heater automatically turns on? This is a major issue especially if this happens after hours on a Friday and the white ink cooks for the entire weekend. Even worse if it's holiday long weekend or weather related extended closure. I've messaged DCS about this so waiting to hear back.
InnoJet_cs
The heater should be turned off EOD/W. Once it is off, it should not power back on due to power instabilities.
