I don't get this statement.I would think you want to direct print 20 4x8s. I can do 1,000 other things while the printer is running one board, when its done, load another and go do another 1,000 things. Why would anyone be standing there waiting for a board to finish so they can load another? I would rather operate this way then run a roll of vinyl, cut it to pieces, trim them and lay them one at a time. Seems to me if you are doing 20 quantities of anything, flatbed is the only way to go.Now of course if your printing 20 4x8s, you can load a roll... Hit print and walk away, it'll take less time to apply the vinyl and trim than it would to stand at the flatbed constantly loading sheets and hitting print.
I'll take 3 Hours of production total at a higher margin vs 1.25 days worth of work at a lower marginYes and no, say your flatbed takes 8 minutes to print a 4x8 sheet, you load the sheet, hit print, prep the next sheet to go on (wipe it down) and you have maybe 5 minutes left before you need to remove the sheet and start all over again, from a productivity point of view, what can you really accomplish in 5 minutes or less, you probably can't even answer an email in that time.
with a roll to roll printer, you load it, print and have 6-8 hours to get other stuff done while the printer is working unattended. come in the next morning and use a rolls roller table to mount all 20 sheets in about 2-3 hours
I'm not saying one is better than the other, but they each have their pros and cons. The flatbed really shines because it removes the cost of the vinyl and laminate from the equation. and if you can get one that is fast enough to print a sheet in less than 5 minutes then you can keep an employee busy loading/unloading/prepping the machine in an assembly line like fashion, if it takes longer than that there is going to be idle employee phone checking time.
With this math its not even 3 hours to do 20 sheets by flatbed. You have to wipe down the sheets whether you flatbed or mount a print too. If you print you have to move the material off the printer, onto the laminator, then cut it down before you can mount it. A decent calendared vinyl and laminate will be close to $1/sq ft not including ink. So if ink costs are the same, straight away the mounted print is costing you $32 which is in the ballpark cost of a labor hour in a smaller shop. So even if a flatbed took 1 hour per sheet and a guy sat there the whole time you would still be money ahead if you aren't counting machine depreciation.Yes and no, say your flatbed takes 8 minutes to print a 4x8 sheet, you load the sheet, hit print, prep the next sheet to go on (wipe it down) and you have maybe 5 minutes left before you need to remove the sheet and start all over again, from a productivity point of view, what can you really accomplish in 5 minutes or less, you probably can't even answer an email in that time.
Both options have around 3 man hours invested in them, I'm not counting print time for the roll to roll because it doesn't tie up an employee while it's working.I'll take 3 Hours of production total at a higher margin vs 1.25 days worth of work at a lower margin
We have both and we find no matter what if the durability and quality fits direct to substrate is far superior in efficiency than mounted vinyl.Both options have around 3 man hours invested in them, I'm not counting print time for the roll to roll because it doesn't tie up an employee while it's working.
At the end of the day you have to decide what setup works best for your shop, I assume anyone who has a flatbed also has a roll to roll machine because there is no one size fits all.
For us we have only had UV for 6 months. Vibrancy hasn't been a problem on our fb... it seems very bright and glossy depending on substrate and curing protocol. We have experienced some ink fade in 6 months on coroplast, but that is a cheap substrate and not designed for long term usage.The UV prints look somewhat dull to me. I don't fully remember but I want to say that when I was a kid and we screen printed with UV ink and drier that the prints were just as vibrant as air dry inks. Why is it different with a printer?
And 2ct, as far as ink durability, how much of this do you think this has to do with flatbeds primarily printing on cheap substrates? From recollection, UV ink held up really well but its only as good as its weakest link.
WhichIt's how the ink droplets sit on the media. UV actually sit above the media while eco and latex penetrate into the media. because the UV sits on top of the media, it
cannot give a glossy finish as it wont be a smooth surface vs eco & latex.
And if your Flatbed prints are dull, then i'd be checking your profiles. My prints are amazing.
