Versa Works Contour Cut is Driving Me Crazy!
Discussion in 'RIP Software & Color Management' started by rdm01, Oct 29, 2008.
  1. rdm01
    rdm01 Very Active Member
    1,016
    Dec 28, 2007
    Portland Metro Area
    So I am trying to have something contour cut in versa works, and the will not
    work. It seems like every fifth file is like this. I use the contour cut swatch in
    Illustrator and put a stroke around what I need like I always do but sometimes
    it does not come through in versa and it is driving me crazy! Any ideas on
    what to do about this or what could be causing this problem?
  2. Bigdawg
    Bigdawg Just Me
    7,462
    133
    63
    Jun 8, 2005
    Sunny Florida
    Are you using it with transparency in Illustrator? Drop shadow, etc? If so, that's the cause...
  3. Sites&Signs
    Sites&Signs Member
    186
    Also make sure the stroke is set to the center and that the weight is .25
  4. Bigdawg
    Bigdawg Just Me
    7,462
    133
    63
    Jun 8, 2005
    Sunny Florida
    That shouldn't make a difference... I routinely forget to change mine from 1 pt to hairline...
  5. rdm01
    1,016
    Dec 28, 2007
    Portland Metro Area
    It must be the transparencies! What a pain in the arse, I really don't want to have to loose them.
  6. ericmitchell29
    ericmitchell29 Active Member
    632
    Mar 18, 2008
    Maine
    Big Dawg got it right. Its the transparency settings on some of your elements. One way I get around it is... export it as a high quality jpeg and then import it back into the proper space...
    Make sure you save it as a different file so you don't lose your original incase you need to edit it down the road.
  7. Mason
    Mason Very Active Member
    2,037
    Aug 11, 2005
    Boston
    That should make no difference at all, I routinely use a 1pt stroke on all my contour cuts in VW from Illy
  8. rdm01
    1,016
    Dec 28, 2007
    Portland Metro Area
    Yeah, what a pain in the ***. It seems like and easy fix for them, but then
    again I am no programmer. I ended up just having two files in versa works,
    one is the print file, and one is the cut file (print file with transparencies
    flattened), and used that when it came time to cut. I just had to make sure
    both had identical setup and it worked fine. Thanks All!
  9. jasonx
    jasonx Very Active Member
    1,319
    30
    48
    Aug 5, 2007
    Australia
    Select everything besides the cut line and flatten the transparency. Save the EPS and you have no problems.
  10. kustomsigns&designs
    kustomsigns&designs Member
    434
    sorry to change the subject here but does anyone know how to add a cut line in photoshop cs3?
  11. anotherdog
    anotherdog Very Active Member
    1,191
    I would think it's the same CutContour swatch used in illustrator.
    Haven't tried it, but I'm pretty sure its just 100 magenta, spot renamed "CutContour"
  12. rdm01
    1,016
    Dec 28, 2007
    Portland Metro Area
    I run into color problems when doing this. I have a gradient with 10% opacity,
    and when I flatten transparency it ends up totally effed!
  13. TonyHoles
    TonyHoles Active Member
    580
    Good work around I have used that method for similar situations.
  14. SOA
    SOA Member
    209
    HELLO!!i had is same problem!!Let me tell you how to do this real EASY!!!the problem is caused by transparency layers, i also didnt want to loose them either!all you need to do is select the cut contour and the weeding box (if your using one) group them and bring them to the front of the document,then when saving, make sure you select HIGH RESOLUTION & LANGUAGE LEVEL 3,without doing the last 2 steps you will have the same trouble.(this is for illustrator).
    Hope this helps! all the best
  15. SOA
    SOA Member
    209
    also... you wont have to flatten your images if you follow these directions :)
  16. fuzion1
    fuzion1 New Member
    2
    You are the Sh_t! Worked Sweet.
    Just a note, yeah the 1pt stroke dont matter
  17. scarface
    scarface Guest
    I always save as a cs EPS file from CS3 and i haven't had no problems.
    Make sure you set the stroke weight to .25 and you should be golden.
  18. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    reddhartgraphics: I owe you a cold one or 30!
    That has kicked my butt for years.
    Several calls to Roland with no help except to flatten the file.
    Then you can't edit it, so I would keep 2 files.
    1 original & 1 flat.
  19. In the Stroke pallett make sure Align is set to "Center".
  20. darrellcarpenay
    darrellcarpenay New Member
    4
    I got this same problem so I tried the flattening the image and it worked. Thanks
