Versa Works Contour Cut is Driving Me Crazy!
rdm01
So I am trying to have something contour cut in versa works, and the will not
work. It seems like every fifth file is like this. I use the contour cut swatch in
Illustrator and put a stroke around what I need like I always do but sometimes
it does not come through in versa and it is driving me crazy! Any ideas on
what to do about this or what could be causing this problem?
rdm01
It must be the transparencies! What a pain in the arse, I really don't want to have to loose them.
ericmitchell29
Big Dawg got it right. Its the transparency settings on some of your elements. One way I get around it is... export it as a high quality jpeg and then import it back into the proper space...
Make sure you save it as a different file so you don't lose your original incase you need to edit it down the road.
rdm01
Yeah, what a pain in the ass. It seems like and easy fix for them, but then
again I am no programmer. I ended up just having two files in versa works,
one is the print file, and one is the cut file (print file with transparencies
flattened), and used that when it came time to cut. I just had to make sure
both had identical setup and it worked fine. Thanks All!
jasonx
Select everything besides the cut line and flatten the transparency. Save the EPS and you have no problems.
anotherdog
I would think it's the same CutContour swatch used in illustrator.
Haven't tried it, but I'm pretty sure its just 100 magenta, spot renamed "CutContour"
rdm01
I run into color problems when doing this. I have a gradient with 10% opacity,
and when I flatten transparency it ends up totally effed!
TonyHoles
Good work around I have used that method for similar situations.
SOA
HELLO!!i had is same problem!!Let me tell you how to do this real EASY!!!the problem is caused by transparency layers, i also didnt want to loose them either!all you need to do is select the cut contour and the weeding box (if your using one) group them and bring them to the front of the document,then when saving, make sure you select HIGH RESOLUTION & LANGUAGE LEVEL 3,without doing the last 2 steps you will have the same trouble.(this is for illustrator).
Hope this helps! all the best
S
scarface
Guest
I always save as a cs EPS file from CS3 and i haven't had no problems.
Make sure you set the stroke weight to .25 and you should be golden.
TresL
reddhartgraphics: I owe you a cold one or 30!
That has kicked my butt for years.
Several calls to Roland with no help except to flatten the file.
Then you can't edit it, so I would keep 2 files.
1 original & 1 flat.
