Need Help VersaWorks 6 Thinks EPS Files are Corrupt
Falcon187
I didn't say move it, I said open it in the program you created it in, save it to desktop and then open it in versa from there and print it.
I have tried everywhere. As I've mentioned before...VersaWorks 5 can rip them just fine. VersaWorks 6 on 2 of our PC's think these same files are corrupt. All other PC's VersaWorks 6 can rip them just fine. I have redownloaded VersaWorks 6, I have reinstalled Windows, I have upgraded Windows....I have searched everywhere online and there seems to be no explanation
texasvinyl
I am having the same issue as you are, Falcon. Have you come up with a solution? I have two computers and one worked until last week but the other was having the same issues as yours. I tried all the same fixes as you as well, including restoring Windows back to the beginning.
Dale D
As a work around, you can export them as a pdf in a file location then use Versaworks to open the file. If I use the Blue "Send to Versaworks" button in Flexi, sometimes I get corrupt files.
texasvinyl
Thanks Dale D, I am currently using .tiff as a work around but I have also used .PDF like you suggested and it does work. However, I don't know if "print and cut" will work in those formats like .eps will. I haven't tried yet.
Falcon187
No solution was ever found. We are continuing using the PC's that are working while the ones that don't are strictly for designing on.
