You need to reduce your heat, also you need to shrink your XY bar thickness. It's not compensating enough, and the heat is probably causing most of the center path bowing.
You are also asking for trouble with the tight bleed margins on latex.
We do .5" circle decals on our 570 with a summa and they are nearly dead on. It's either an equipment defect, setup issue, or user error. With out knowing the whole process it would be hard for me to lend guidance.So are these machines not made for precise stickers? because everyone else has been telling me that this machine smokes the rollands and I should have no issues doing this... How low heat can I go if I up the passes to like 22?
Must have accidentally bumped the button while scrolling.BVG - why thumb down? I own machine and I know what it can, and what it can't do.
I also owned Roland GX500, GS, PNC, Roland VSi and I never experience this kind of problem. It was always a user error. With HP54 is a lottery. One cut is perfect, the next day the same one starts to "drift" - same cutter, same material, same job. Like it accumulates rounding errors. Maybe it's Flexi problem, but that's software bundled with it so...
How fast are you trying to cut? Learn to walk before you run. Are these laminated? Are you using the original blade? What degree? How much of the blade is exposed from the pen? It should only be enough to scratch the material.
If you have to much blade exposed, the degree of the angle is compromised and accuracy can be lost.
What grey squirrel is is all facts verify to find the root cause. We have the non rebranded and tangential version and don't have the issues described. So it either is a process problem or a defect, those questions lead to the answer.@graysquirel
If you can't help just read and move on. No need for this.
I have the same problem with the cutter and I was able to "fix" or "do workarounds" for my friends with cheap, no name, generic cutters to do an awesome job with small stickers.
I couldn't do that with HP Latex 54 --- until now.
Yesterday I cut 600 really small long stickers (100x10mm and 110x15mm) - awesome job, no errors. All I changed was SAi Flexi (a new version). Give it a try. You can download it from SAi cloud with your credentials.
Now you have Flexi 19 there.
Settings:
HP Barcode - on
Cutting speed 4 IPS
(I used 105g of pressure - thicker vinyl so... adjust accordingly)
