gabagoo
But....
KMPF don't recognise your method of panel fabrication as being acceptable because from a UK perspective it's not.
Back lit sign panels like yours should be produced from quality cast Opal acrylic. The sizes you are working with dictate a minimum of 5mm acrylic thickness. All panels should be cut undersize and fitted with hanging bars to facilitate a "float" fit inside the cabinet.
KPMF are a UK company so it's perhaps not unreasonable for them to judge your project using UK standards.
Used on a suitably thick piece of cast acrylic both KMPF & Ritrama translucent films work just fine.
Based on that theory...why in hells name are they selling the stuff without a spec sheet...because no one would buy it no doubt....
99% of every signface I have ever worked on was 3/16 roll stock so that meets your 5mm standard... and I have yet to have a problem with translucents....I don't use Ritrama thankfully.
