CheapVehicleWrap
Then you have never had this problem,, right,,,
He did. And i have as well. I also discovered the cause long ago.
Do I have to make a vid to show that stretching will occur even with transfer tape?
Especially if improper technique is used,,, vinyl can be stretched so much that the the unsqueeged part will stand straight up. So, sorry, but premask will not prevent stretching.
Look at those sheets. They all fail in the points of cuts. It is just like concrete where stress cracks always appear at a corner. Same with this vinyl. It is cracking at corners. All caused by shrinkage of some amount.
Dated vinyl does not shrink just because it is old. Also, I have/had a load of vinyl that is at least 6 years old and all of it still applies just fine. Although i do not cut much of it any more.
Those crack lines are caused by shrinking. He used calendared trans vinyl and/or,,, it was stretched when applied.
+1, but you have to admit it still looks cool lining up with the cuts and all.
