Why Gerber is for house wives and mommas boys....
rockz12
Specializing in the strange and unusual
This a reply to an earlier thread. I'm sure there are some of you who will live by the Gerber and die by the Gerber. Others think it is overpriced and useless. These are a few things to consider when buying one. I will list better ways to spend your money later.
13 reasons why THE Gerber is less than desirable...
1. The Gerber Edge costs 17,000 dollars
2. Process printing looks horrible
3. Process printing cost $2.80 per square foot in film
4. Price for foils is .55 - .86 per square for common colors.
5. A library of colors is required to do a quick turn on a job - this requires a lot of $$$ laying around the shop doing nothing
6. Spot colors print serrated.
7. You are limited to 15" material and you can only print 12"... Oh sorry sir you want a big decal? We can only print 12" we can't do that!
8. Materials cost a lot more Example: Controltack 180c-10 $1.61sq.-gerber 1.03-Inkjet
9. Do we have enough material to finish the rush job? Well I guess, I dont know how much is left in the cassette... Gerber finally figured this one out in the latest FX
10. Foil is completely wasted if it is not utilized right. Waste of $$$$
11. You have to use The OMega...
12. Not economical in large quantities and too expensive for short runs. If someone wants 1000 1/c tomatoes in tomato red just screen print it.
13. You have to buy the sprocket cutter for $3,000 and it can only cut 15"
Poconopete
Instead of bashing Gerber, a lot of people make $$$$ with it, why not list your printer of choice and why you like it. Every printing process has pros & cons.
............ and your point being ???????????????
Do you realize how many inconsistencies you have within your rant ??
….thus making it sound prejudiced. What’s the real problem here. Are you feeling unwanted or gypped ??
rockz12
What is not a fact in the statements I made? What is inconsistent? Im sure the gerber does make some people money. I am just educating the potential consumer. The gerber is a very expensive machine to run for the volume it is intended for.
Relax, take some deep breaths and count to ten.
You're upset and some of the things you say are true to some degree, but on a very biased sense of terms.
You sound like a very disgusted individual right now.
You made the statements.... it's up to you top prove each and every one of them and I'm pretty sure you can't.
Replicator
What it is intended for is a very specific market and you may have been a fool
to purchase equipment that did not suit your specific needs as well as you
thought when you got suckered into buying it, while not knowing what you
were getting . . . Just a guess !
B Snyder
rockz... Find and report the sources that back up the information you posted.
#7 is the only item I'll concede, assuming tiling is not an option.
Fred Weiss
OTOH ...
  • Gerber brought their Edge products to market long before outdoor inkjets
  • My Edge system has consistently grossed in excess of $5,000 a month since I got it in 1998
  • Spot colors are a positive not a negative ... no color management concerns for openers
  • I don't have to laminate my prints, or let them dry, or deal with subdued fumes that may shorten my life
  • Process color looks fine if you go to the trouble of learning what's involved
  • Omega is designed for running an Edge but for those that insist, you can also run it from Flexi or SignLab
  • When you look up freedom and reliability in the dictionary you will find Gerber listed for it's sprocket fed plotters
  • When you look up profitability in the dictionary, the Gerber Edge is high on the list
Billct2
Yes
No, I've done large paneled photos that looked fine, before other options became availalbe
I haven't checked prices lately, but I mark it up so much who cares
see 3.
Same can be said for vinyl, at least they don't go bad
???That is a problem of your software or design not the edge, it prints perfect solid clean edges
Ever hear of tiling? I've done tractor trailers on my Edge
Materials choices are unlimited and vinyl for the edge is no more than any other vinyl
Yea, but you get used to estimating how much is there
So is any material that isn't completely used, it's figured into the cost
I do, but I understand iother format are now supported
It's always best to chose the correct technique and material for every job
Yes, but they're great plotters, I can print cut unlimited lenghts with great accuracy
There are other postives (and negatives with the Edge) but one great thing is it's
ease of use and incredibly low maintenance (as with the plotter) Also lamination isn't need, though we frog juice most of our prints.
It's also great for jobs that other machines can't do, like mettalics, there are tons of materials and use for the machine.
B Snyder
FX, GSx plotter, Omega and 10 foils/caddies....$14,995
www.gspinc.com
If you don't know how to utilize the equipment and software your prints will look horrible on any machine.
http://www.advantagesignsupply.com/events/index.php
My foil cost is $1.48 using ZeroNine foils.
www.zeronine.com
Again, much less.
Again, www.zeronine.com
I'm always printing. If your foils are "laying around the shop doing nothing"
the problem could be sales, marketing or design skills.
www.ziglar.com
See reply to #2
Tiling is an option.
I pay 20% off the list price of $255 for a 15x50 roll of 180c. (=$1.36/ft)
EDGE, EDGE 2 and FX foils have a printed "Gerber Gauge" on the foil. Zeronine has the "Shuttle Cartridge."
Customer pays for it whether its used or not...the same way they pay for "wasted" vinyl.
Really?
www.scanvec.com
www.signlab.com
That depends on the specifications the client requires for the completed product. There is not one single way to produce all output efficiently and econonomically.
13. You have to buy the sprocket cutter for $3,000 and it can only cut 15See reply to #1.
You could use any friction fed plotter with an optical registration system but if you ask anyone who owns a sprocket fed Gerber cutter if they'd rather use a friction fed machine to cut their prints they'd think you're nuts.
www.4edgetalk.com
ndemond
Been using Gerber since 1993. Just got Omega last year and have the 750 30" enVision that has been down for all of 24 hours since I purchased it used. I have a good relationship w/ customer service, pay the extra for extended consult, no problems here.
Oh I am a housewife, mother of 4, and have been in the sign biz for over 25 years, and you?
The Sign Dude
one good thin about and edge is the ink doesnt dry in the lines and clogg it up.
I made tens of thousands of dollars a year with my 5K investment on my edge and hs15 plus. the gerber plotters are a true workhorse of the industry.
rockz12
Yes
- Even 15,000 is too much - why not buy a Solvent printer? Better quality, at least more than twice the size 38", a used one can be bought for half the price of a gerber.
- Halftoning is flat out horrible
- Are you sure your making money? If you dont know what your paying for supplies how do you know how much to charge?
see 3.
- see3 5. A library of colors is required to do a quick turn on a job - this requires a lot of $$$ laying around the shop doing nothing
- I dont need 50 different rolls of vinyl in stock to get a job started 6. Spot colors print serrated.
-By the time you overlap, each panel will be 11" An average car is 12' wide. 14 panels per side? How many panels did you install for a tractor trailer? Seems like a lot of labor... what did it cost your client? Should have outsourced you would have made more money 8. Materials cost a lot more Example: Controltack 180c-10 $1.61sq.-gerber 1.03-Inkjet
-It is more expensive
-That is what the captain of the titanic said.. Full speed ahead 10. Foil is completely wasted if it is not utilized right. Waste of $$$$
-True, but a little more expensive with the gerber
- I agree 13. You have to buy the sprocket cutter for $3,000 and it can only cut 15"
- They are good cutters, but you could put that money towards a summa and do the same think in wider format. Why limit yourself?
