Console Stuff
grafxxx
are these just for you. or are you selling those designs.? they look great just a warning about the mega death art on there.. but again they came out clean i really like the screaming skull one the best.
B-RAD Graphics
if CS2 wont let you open them, just create a new file and then drag the eps into illustrator onto that new document and then up at the top, click "embed" and illustrator will load it anyway. its a workaround but it works just fine.
if you need clearer info let me know
Where is the embed hidden?? :thankyou:
S
scarface
Guest
I know this thread is alittle dated but i see your all using 3m 180c, now most of my work is on 3651 with 210 lam.
Does anyone know if that would work for this as well?
FatCat
Scar, most are using the 180 because it is a cast material primarily used for wrapping. The 3651 is a calendared material that is used for flat surfaces or very minor curves. Two completely different animals.
strypguy
I've used 3165ra and 3651 with 210 lam on console wraps. I tried them out on my kids wii first, as a test, and that was months ago. Looks good!!
John
S
scarface
Guest
I cut the templates today on masked vinyl and i can't get the blade to cut through the tape and the vinyl enough to weed the excess away. It scores the back of the vinyl but that's about it. I've tried 5 different force settings on a 45 degree blade....any help?
Malkin
Even if the application is flat, there is an advantage to using a cast film. Because it's more dimensionally stable, you will have little to no shrinking issues over time.
S
scarface
Guest
when you guys send this to the RIP, does it print like this or do you print it in masked mode? I'd think in masked mode it may go off track some, no?
