Applying window perf
Discussion in 'Vehicle Graphics' started by MGraphics, Aug 8, 2011.
  1. MGraphics
    MGraphics Member
    146
    Hello all,
    one quick question... applying window perf wet or dry? on a back window with no lam :smile:
  2. Kyle Blue
    Kyle Blue Member
    176
    Wet.
  3. SebastienL
    SebastienL Active Member
    604
    I'm not an installer... but I'd say dry.
    If it's on a back window of a car or truck, it MUST be laminated, at least in Ontario and Quebec.
  4. Sticky Signs
    Sticky Signs Very Active Member
    1,154
    Nov 9, 2009
    Vancouver
    Dry. the water will cause cloudiness.
  5. d fleming
    d fleming Very Active Member
    2,795
    232
    63
    Nov 28, 2007
    Middleburg, Florida
    W/no lam we go wet. One person either side of vehicle, drown it and freehand place it.100's of apps, not one failure. Using rapid tac II
  6. MGraphics
    MGraphics Member
    146
    thanks Pat
  7. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,847
    70
    48
    Feb 27, 2007
    World
    Why would anyone install perf. vinyl wet, it's so easy to install unlaminated.
  8. BLC411
    BLC411 New Member
    19
    Jun 14, 2011
    Champ
    Perf
    Dry. No reason to apply wet and the manufacturers of the window perf film will not recommend applying wet. Window perf is easily installed Dry, especially without laminate. Just my two cents.
  9. sghobbies
    sghobbies Member
    305
    Jan 18, 2008
    Adel, GA
    +1. Too easy to do dry.
  10. SignaramaFL
    SignaramaFL Member
    240
    dry, easy to install laminated or unlaminated.
  11. john1
    john1 Guest
    I have never done perf wet but it's REALLY easy to install without bubbles dry so i would do dry like i been doing. I would just add lam onto it, i mean it's not much more expensive and will look and hold up better. The holes will fill up with dirt and look terrible if it's not laminated.
  12. ucmj22
    ucmj22 Very Active Member
    1,509
    1
    +1 We always laminate and apply dry
  13. TedNes
    TedNes New Member
    19
    More important than wet or dry -----I say dry by the way----- could be 'What's on the glass?'...
    If the vehicle is factory new, you may have a problem. Also, is the customer a 'Rain-X' user----that stuff will cause no end of headaches when it comes to adhesion....
    If the vehicle is brand new, or Rain-X/a rain dispersant has been used, you will need to clean the glass many many times with degreasers and alcohol based products before you want to apply....
    Oh, apply DRY....has that been mentioned??
  14. GZ SIGN DESIGNS
    GZ SIGN DESIGNS Member
    130
    Dry all the way
  15. Sticker Dude
    Sticker Dude Member
    397
    Mar 26, 2006
    Florida
    Im with Pat White
    Dry all the time
  16. petepaz
    petepaz Major Contributor
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    dry and i just did one with out lam by customer request. i did it with lam and he said he couldn't see out the back so he pulled the lam off leaving adhesive on the print and all the dirt stuck to it then when he tried to clean it off came the ink. he paid for the re-do but he claims he can see better with out the lam...?
  17. ucmj22
    1,509
    1
    do you use optically clear lam?
  18. ABPGraphics
    ABPGraphics Active Member
    607
    I spent my money on clear lam and it just did not work for me - on the outside it got this shine to it that would not go away and it did not show thru optically clear at all
  19. petepaz
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    i used the correct, optically clear lam. after i did the job i poked my head in the window and looked out, looked ok to me. customer wears glasses so i don't know?. didn't cost me anything to do it over again so if that's what he wants so be it.
  20. ucmj22
    1,509
    1
    it will look great at first. I bet he'll hate it when the little holes fill up with road gunk.
  21. MGraphics
    MGraphics Member
    146
    installed it dry... very easy with no lam... thanks for all the help :)
