somebody better straighten me out here.... What exactly is the difference between a laminator and a mounter? I thought they were one and the same?
Laminators tend to be built with more precision that mounters.
YAY!!!!
Ran it for the first time. Apart from an odd right-hand-twist sort of pattern showing up after about 4 feet (that didn't transfer to the vinyl, just showed between the rollers). It came out GREAT. For the price, and even not just for the price. The only suggestion I would make to them would be to re-engineer the stand. That is really a disappointment compared to the stands on my Graphtec and Mutoh. I know they're huge companies, but a stand shouldn't be a tough piece to design.
Other than that, if you're a one-man operation (or 2 or 3) then the Daige would probably be the best investment you could possibly make. Also, with the larger machine's penchant for wasting footage each startup, I would say every large shop should have one for in-between work. I can leave this thing threaded and ready-to-go. I love it.
Beginner's luck, that's all I'm going to say. In the middle of a 3 hour FIT trying to understand why the take-up reel drive (rubber band) just slips over it's pulley and screws my job. I'm going over the diy instructional video and nothing's covered there.... you had better have an OVERFLOWING cup of patience. If you're a patient person, it's a great machine. But I agree with some of the other posts, not really sure it IS worth the money. It's like a college student vs. a professional. Plenty of shortcuts that probably saved Daige money, but don't translate well into the real world. Wish me luck, or somebody's gonna walk out of my shop with this thing lodged in their A@#.
No they slip like a mother f er....The belt is coming off the pulley??
that what i said till i got on my 3rd roll of lam...then it started slipping ...its worse when the take up starts getting full.So far, so good with my 55" model. No problems mounting or laminating.
The only thing they say is you need a new belt,,ive been threw 3 belts in less than a year.,,even doing a figure 8 setup on it the belt will slip. Im about to find some sprockets and chain for it.PMG - are the white bushings at the ends of the take-up shaft still in good condition (smooth, not rough or gouged)? What about the grooves that the bushings sit in? If you see or feel any burs, smooth them out.
If that's not it, have you tried cleaning the 2 take-up pulleys and the clear rubber drive belt? If you used silicone spray or WD-40 on the outfeed table and some got on the belt/pulleys, that would play havoc with the feeding.
Also make sure the belt has a decent amount of tension on it and hasn't been stretched too much.
I just went back and looked at mine and that's all that came to mind. Otherwise, I guess a call to Daige is the next step.
Good luck!
gtg
...Im about to find some sprockets and chain for it.
Good luck!
gtg
