Here are pics of the one we built using Faztek materials and a 60" pneumatic HSRA.
I would think that keeping the table completely flat would be a major problem- looks like you are using MDF?
... is the bed 12' long? John
You could also use one these to drill holes View attachment 102744 but why when you can use this View attachment 102745
Bigben- that is interesting as well- what was the price? Google only comes up with the same video. Is it imported into Canada by someone? Thanks Gene
We use one of these laminators. I might not be able to hit 3 minutes cause like you said you would be dead at the end of the day. But I bet I could load mount and trim in 5 mins or under. That being said, I have seen these laminators in action and you can't be faster then them.
I did have a question though. I noticed the entry has no lights under the table. Is the table still translucent. could you hook up your own lighting under. I saw them piecing vinyl together with the light table and it was so quick and precise I would def. want the lights. But if I can install myself.
Are you willing to share your supply list to build one of these?
One other point to consider about these flatbed roll laminators vs. a regular laminator is that you only need half the space to use it....
with a table like this, how do you laminate a print that is longer than 10ft? I often do murals with 12ft to 15ft panels.
