The Weeder Sheeter is the best thing out there. You are not limited to the length of the table you are working on. One person can apply tape to 20' or more of material without stopping. I have mine mounted on a small square tabletop with the weeder set 90 degrees to the sheeter. Pass the vinyl through the weeder then turn it and insert it into the sheeter and you're done! When I started doing vinyl in '99, this was the next biggest purchase after my plotter and it was the best money I ever spent! It works flawlessly... no bubbles, no wrinkles... as long as you can keep turnin' the handle, it will keep applying tape!
I wish the Weeder Sheeter company would make a wide format version of the sheeter that would apply lamination!!! I'd be all over that in a heartbeat!
