Maybe run it as administrator for the install.
Did you check your permissions on the temp folder? Are you running as admin? Why aren't you answering these questions did you get it working?
You kidding me?
Can a guy take a dump and eat breakfast?
You kidding me?
No that's not allowed, :ROFLMAO:
Do you have another PC to try and install it on, maybe the program has issues????
I've tried installing (3) different programs with different temp file errors....
I downloaded and installed CCLEANER, although I already have it installed,
as a test to see if I could install it....it installed o.k.
Hard to believe that three different programs have issues.
Not if you have the windows installer that is broken.. Most of the replies are way off mark.
First of all. I would make sure there are no other programs running. This problem often comes up with a memory full condition. Something may have a memory leak.
Then goto documents and settings folder\ bigal\local settings\temp and clean it out. every thing has to go. That Ins1D1a.tmp.exe has me concerned..
Next you can see it is writing to the my documents folder. Make sure you have full rights to the entire folder tree.
