help, mutoh 1604 cmk banding
elitetech
It wouldnt take it, the previos proflie ithat loaded was(sai) format, in production manager, when i go to import the file, it doesnt show up in the folder.
the presets that i have loaded successfuly before had the a circular color spectrum image on the file, the one you sent had a triangular color spectrum image, if that helps.
Graphics2u
As hard as it is to part with the money, those missing nozzles are the problem. Probably 90% of my printing is solid colors like what you're doing there and if I have even few nozzles missing I can see banding, althought not to the point you're seeing it. No way to hide it. The head may not be bad elctricaly but the nozzles are either damaged fro striking the magnetic material or they got clogged from the head strike or bad seal on capping station. You could do some serious cleaning on the head with syringe and cleaning fluid, but if they don't come back it's done.
Stealth Ryder
Exactly the truth... Until you address this issue you are just spinning your wheels... To answer your question as to how to resolve these issues you are having you have to look no further than this thread, the answer is here...
Before you even think about Head Alignments or any calibration you must first have all the nozzles firing... It is impossible to Align something that is not present!!!
