BigfishDM
Eco solvent, latex, UV printable? Does it need be laminated?
It works in all of those ink sets. It does not need to be laminated but you can laminate it.
It is $299 for Clear and $289 for white and both are 54"x164'Whats the price?
You said it was not vinyl- IOW it is pvc free? I do laser cutting and pvc is a no-no. thanks Gene
Does the outside temp matter? Can it be applied (and stay on) if it is in the 30s outside and the truck doors are cold?
Am I the only one who has an issue with this stuff in the rain? I've tried and tried but consistently when I go through ANY type of rain, the decal lifts, gets dirty and wont stick anymore. I've tried laminated and unlaminated. I've had issues with it cracking into pieces too in the cold. So far not impressed with it.
Well, if it cant get wet its not a comparable replacement to car magnets. I'm glad I tested it before offering it. I also meticulously prepped the area that I was installing it too, squeegeeing with FIRM pressure, and still fails after 10 mins in a light rain.
Well, magnets don't work on aluminum... and neither does this if it can't get wet. I wouldn't call it an alternative if it plain just doesn't work.... Well, maybe in Yuma Arizona it will.
Will it work over printed/laminated vinyl on a sign and be removable after some time? For example, name change on an employee of the month parking sign.Here is another way to use our iDot material, great for cars that are aluminum. (Alternative to magnetic)
