Not sure what you mean be advance the feed roll.
Not sure what you mean be advance the feed roll. As for uneven pressure I did just adjust it using my cobbled together force gauge. Its one of these with strips of banner material.
It was tight on the left side with it falling out on the right side. I got it to within 10 or so grams of force.
Did you purchase the WeiHeng Electronic Digital Portable Scale form ebay and it shipped from China?
If so how long did it take for shipping?
Or did you find one in the US?
Ok I have finally gotten back to the laminator issue. Right after I posted this I had about a month of horrible computer issues. I'm also the network engineer here and we had a server that crashed avery 19 hours day or night.
But anyway after having the laminate travel across the rollers about an inch per 20 feet I adjusted the pressure across the rollers. The lam is not moving a mm now but have another issue that just seemed to pop up.
Here is a video. I didn't want to waste lam so I just ran some left over release paper through it.
[video=youtube;keEecIuxJ_E]http://www.youtube.com/watch?v=keEecIuxJ_E&feature=youtu.be[/video]
I bought the front feeder and the rear power take up real for the laminator. I get everything straight and as you can see very quickly the left side starts to ride up as if the material was fed crooked. If I stop the machine I can slide it over to straighten it up but it just keeps moving over.
I'm I right in that maybe the front roller is messed up or maybe the pressure rollers are not square to the machine.
Thanks for everyones help. I didn't forget about you just I do a lot of stuff here.
That is pretty normal when you feed it incorrectly like that. You surely have an idler roller under your bottom pinch like you have on the top. Why aren't you using it?
Read this discussion for and understanding of how to properly web a laminator. Or how not to.
http://www.signs101.com/forums/show...or-eating-material-(yep-another-one-of-those)
ETA: now that i think about it i tried to use that roller in just that way. the problem is that its not laid out like in the manual, it's much closer to the bottom roller right underneth it. I think in that other thread you refer to the manual. If you look at figure three around page 10 you can see how tight it is. I couldn't figure out how to get the material around that roller and back out. Monday I'll try to make a video showing the problem.
I bought a fish scale from Walmart. It has a dial gauge but considering how cheap this one is I think it is as good or better.
Wow! Thanks for the drawing. That is just plain bad design. I would put some tape on the vinyl and tape it to the bottom idler and get it around that bottom idler roller one way or another.
Using the lower idler roller is difficult due to limited space, but it is hardly impossible. Having a bit of space at the leading edge of the print media will help greatly, or failing that, using a leader that is curved or angled will limit the initial surface area passing around the idler roller, making it far easier to use.
Please see the attached drawing for a visual of this.
(wow I have hairy arms
)Now you need to make something for the rollers to pull on....
