While down at the Atlantic City sign show, everybody was telling me how important it is to have a heat assisted cold laminator. After showing my ignorance of the fact of… why have a cold laminator if you need a heated roller assistant … they said this added feature stops ‘Silvering’ [??] when applying laminate to the vinyl. Duh, I never heard of that. I thought that is what you put on the back of mirrors when they went bad.
After I questioned almost every rep at the show demonstrating laminators… a friend of mine that sells them told me, it’s not really needed at all. The ‘Silvering’ is a term for small bubbles that get in between the lam and the vinyl when starting it. 90% of it goes away while you put the vinyl on the vehicles. The rest of it goes away in a day or two. Who really cares if you see some minute bubbles that are going to go away eventually ??
Sounds like the same thing we tell customers if there are a few bubbles in the application. Ah, yeah Mrs. Jones, the sun will take care of those bubbles… and sure enough they go away.
I’m looking at a ‘Royal Sovereign’. It also has a heat-assisted roller, but I might get the one without it. I just want to be able to put 4’ x 8’s through it without a hitch. We just did 12pcs. 4’ x 8’ x ¾” 2-sided this week. It took about 1 minute to line the vinyl up and about 3 or 4 minutes to actually put the vinyl on the board. Another 2 or 3 minutes to move that board out and set up the next. We had all of the panels finished in about 5 hours total because of interruptions. Delivered them this morning and got the check already.
