Need help removing old vinyl
klingsdesigns
I have a 59x59 area of layered vinyl that needs removed. What is the best advice to remove this. The vinyl is really old. Any info on using vinyl off, or any other products like that?
fresh
yeegads. That looks rough, maybe a power washer? Can you douse it with rapid remover to hopefully soften it up, and then blast it with a power washer? I have no idea, good luck and I hope you are charging by the hour!
klingsdesigns
Right now the customer is doing it them selves and then i have to redo the whole trailer. If he cant do it i will end up having to do it or they are going to replace the sides of trailer. I was looking for something i can get him to help him out.
Moze
A steamer may work...I've been pretty impressed with the results from my use, but haven't done any vinyl in that condition.
You may also try spraying it all with Rapid Remover and then laying thin plastic sheeting against it. It traps the Rapid Remover and holds it against the vinyl. Maybe leave it on for an hour or two and see if it loosens it any.
signguy35
right now I am removing old vinyl off old gas pumps. Im using a steamer and lots of cuss words. The vinyl I am dealing with is old and cracked but not that bad. A steamer and a blade is how I am getting the old stuff off. then I am sanding to get the surface smooth for new digital print. took about 2-3 hours for a 37x45 panel to get vinyl off and cleaned well enough to install new. just about to leave to go do another.
I like the idea of keeping the rapid remover under a plastic sheeting. might have to try that sometime when I am working in the shop, not on site. Good luck.
Modern Ink Signs
Put on a pair of headphones and pick your favorite band with LOTS of albums. That is going to take a looooong time!
I enjoy nothing more that removing old vinyl.....
:banghead:
2B
Have tried a range of methods.
for the really old and brittle vinyl find a high pressure HOT water spray unit, then go back and use a combination of rapid remover and LA's Totally Awesome All-Purpose Concentrated Cleaner.
petepaz
I am worried since its not a flat surface that it will burn through the paint and get hot spots easy.
it might do that. you would have to test but when ever i do stuff like that i let the customer know this could happen and clear up that you are not responsible for any damage during removal. you might even want to get them to sign a waiver. doesn't matter what method you use you always risk some sort of damage or discoloration to the existing paint. i saw someone mentioned a hot pressure washer, that might work but also mentioned and has a track record of working is a steamer (wallpaper remover). very rare that removal is easy especially when the vinyl is in as bad a shape as what you have there
Graphic Extremes
Knows To Little
try using easy off oven cleaner, I use it all the time. Doesn't hurt the paint. Spray it on and watch for a moment, then wipe the vinyl off.
