It is true that Flexi 8.5 can be used without a dongle, but there seems to be some confusion about how it works.
First, you can order it with a dongle if you like, and if you already have Flexi 8, then you keep your dongle and 8.5 will use that.
The dongle-less version is called "softkey" and uses your PC as the dongle. On first launch, it will connect to the internet, then it will connect once a month. So as long as you are connected to the internet at least monthy, it will continue to operate without any errors.
We have no intention of having a server verison of Flexi that you access with a web client. Flexi runs on your local machine, using your RAM and processor. It will only connect to our server to verify the softkey.
The softkey can be moved from system to system - very simular to how it is done in CS2 and CS3. In the help menu is a command called transfer license that will allow you to move it to another PC (you can move it as often as you like - but to transfer also requires an internet connection)
Lets say your PC is lost, stolen, or dies. No problem. We will issue you a new softkey by calling customer service.
The goal is to make the software protection less of a burden, not to put any burden on you. There are certainly some shops that have no internet connection - and those can order the hard key option.
