Resizing Vector Images In corel X3
Red-Eye
It's a cocut problem, not corel.
I tried cocut, and got frusterated with it and gave up, but mine was doing the same thing. Just dont recall what to do to correct it.
I have the info in my email at work....i can try and find it tomorrow when i get there.
Techman
Also, if you have the wrong drivre installed it wil cause a problem
You can edit the drivers your self by pressing cont/shift P.
Look to make sure the driver installed matches yoru cutter.
Open the driver editor as said above. Look at the 4th line down and see what the driver name is. IT should be the same name as yoru cutter
Then look farther down to about line 11 Plotpointx
and plotpointy and see what the settings are. should be something like .01.
Ken
Try viewing the image in wireframe mode..you may find some objects not shown otherwise.
Ken
OldPaint
R T F B.......for corel and cocut........(it is english, you cant figure R T F B out?) no wonder nothin is workin right.......we can help you once YOU GET THE BASICS.......that you need to do on your own.....
