Inkfish Graphics
Again, can these be used in Flexi?
I think I remember it not being available in Flexi. Something to do withAgain, can these be used in Flexi?
Yes they can be used with Flexi. My Roland tech gave me a Flexi SWT (Swatch Table Library) file that works great. Call your dealer they may have a file they can send you.
I had an issue with doing gradients in illustrator with the spot colors, it seems to only print one spot color in the gradient and leave the rest white. Anyone else try this yet?
Make sure to check on that "CONVERT SPOT COLOR" in versaworks when you use the Roland Swatch.
I used to use Roland Swatch in illustrator and didn't turn on that COVERT SPOT COLOR in VW and the colors didn't turn out right
I have been experimenting with this- it will work but it is labor intensive to
set up. You need to use the Roland spot color names with the cmyk values
and then change to a spot color- VW will then recognize it.
I have tried this- he knows of nothing available- could you make this
available. Thanks Gene
Where do you find the printable swatch samples?
Matthew
BlackIceFX
You cannot use the VW swatches in a gradient since VW converts that one color code over to the CMYK. When you use the swatch in a gradient and save it as an eps it wont save the gradient info as far as which swatches were used, it should only save the CMYK values that are being used. I hope that makes sense, I had tons of problems with grey gradients i was dont in a wrap and latter found a long way around, but that was using photoshop.
As far as using the color swatches, I actually use the CMYK values that are associated with the color and not the swatch code and the colors still come out the same, and yes I am checking the box in VW.
I'm with rollerchicken,
is there any way to use the VW colour swatch in photoshop?
Kinda new to this but I take it when you talk about using the swatch in Illustrator that is for creating things from scratch.
So what about images/logos etc that have to be photoshopped? How can you get the colours to match (i.e no magneta in the yellow etc) when you import an image from photoshop?
Hope that makes sense
Rich![]()
Advice please... Sorry i'm new at this. Been clicking in Versa works on some pics and the " File format, convert spot colors" is locked. Doesn't allow me to tick.Here's a screen shot from Versaworks. This is under the File Format window. Note that it tells you how it will print the color in CMYK.
Just assign the swatch as a spot color in your program and you should have no problem
