Doyle
I've never seen this before, and I would never attempt it... There is a 4x4 post in the ground, about 3' above grade. Then there is a PVC post sleeve over it, hollow above the 4x4 post (total height approx. 9'). Two posts like this were supporting a 4' x 4' alumalite panel mounted between them. So the sign was attached to two hollow PVC post sleeves with a couple of PVC supports that went across the top and bottom of the sign. The only real support was the 4x4 posts in the ground and the lower 3' of the PVC post sleeves.
Customer called me after a wind storm when the sign ended up blowing down the street and tearing the frame apart. The sign had been like this for a few years and it blows my mind that it lasted that long....
