UCJV330 Pull Back Printing (Multi Layer printing)
sad_makaronchi
I'm currently printing color >pullback then multiple overprints of clear, so unfortunately no way to do this without multiple overprints of color.
I will look into blade offset. It also looks like there is a setting for registration mark offset in the Image Edit page. Not sure if this offsets the placement of the marks, or the reading of the marks, but I try to will play with it today and see.
Try to expand area of search mark, maybe it is will solve problem
RonnyCrack
Print white layer, then pull-back media and print clear + cmyk
Do you happen to know of any other operation parameter functions? Specifically, I am looking for a way to lower/disable only the back half of the UV LEDs.
When the print starts, only the front half of the LEDs light up, and an inch or two into the print, the back half of the LEDs turn on. I am trying to lessen the cure on my prints for testing multiple overprints of embossed gloss.
sad_makaronchi
Вы случайно не знаете о других функциях параметров работы? В частности, я ищу способ понизить/отключить только заднюю половину УФ-светодиодов.
Когда начинается печать, загорается только передняя половина светодиодов, а через один-два дюйма от печати загорается задняя половина светодиодов. Я пытаюсь уменьшить время отверждения на моих отпечатках для тестирования нескольких наложений тисненого глянца.
Maybe adjusting uv intensity help you, I don't know exactly
sad_makaronchi
Do you want to get something similar? It printed on ucjv300 with pullback, cmyk+white+clear
