Vinyl not sticking on painted wood.
Discussion in 'Vinyl' started by Aragons, Dec 8, 2010.
  1. Aragons
    Aragons New Member
    10
    Hi everyone i had a question and hope someone could help me out.
    I made some signs out of painted wood and the vinyl sticks for a couple of days and then it starts to come off has anybody had this problem?
  2. NAC
    NAC New Member
    10
    Hi Aragons
    What is the vinyl & do you know what the paint is? Potential of being a low surface energy.
    Have you tried a tape snap test?
  3. Pat Whatley
    Pat Whatley Major Contributor
    8,593
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Did you paint the wood with house paint?
  4. Dave Drane
    Dave Drane Very Active Member
    2,540
    1
    And....water based paint????????????:wink:
  5. kkamauu
    kkamauu Member
    54
    need to make sure the board is primed well and then have a finish paint on there if needed - or the vinyl will peel. We typically used MDO primed plywood for real estate signs and other out door signage when applying adhesive vinyl or the RTA vinyls.
  6. petrosgraphics
    petrosgraphics Member
    351
    3
    18
    Feb 24, 2010
    cape cod, ma
    you will have some problems with latex finish coats... we always use oil base enamels...
  7. Deaton Design
    Deaton Design Very Active Member
    1,602
    2
    I use both type paints, but dont have any problems with using latex on mdo and getting the vinyl to stick and stay there. I use satin finish most of the time also, in a high quality paint.:smile:
  8. ddarlak
    ddarlak Trump Hater
    why don't you just order some signs from a sign shop?
  9. Poconopete
    Poconopete Very Active Member
    1,299
    1
    Some latex paints contain silicone= vinyl won't stick. If the wood is still usable, remove the vinyl, hit it with clear enamel, let dry, apply new vinyl and you'll be good to go.
  10. fmg
    fmg Very Active Member
    1,466
    Maybe they are a sign shop and asking a legit question.
    Typical smart *** comment here from a regular!
    No wonder this place gets such bad representation from ex banned members like yourself!
  11. NAC
    NAC New Member
    10
    In my former life I orchestrated controlled peel adhesion tests on all Resene Paints (A local paint manufacture in NZ) using both a permanent cast film and a removable polycal film. To cut a long story short it’s not so much about if it’s an Acrylic or an Enamel based paint, there are good and bad in each, it’s more to do with what they put into them and the finished surface rheology.
    In layman’s terms
    Have you seen an ad on TV where young Johnny goes and marks a painted wall with crayon then mum comes up and wipes the mark off? Well that has keep clean additives in it and stuff don’t like sticking to it. What do we want to do? Stick stuff to it!
    The place I use to work for have since tested all paint manufactures in New Zealand, again it’s more to do with what they put in the paint, and that company now has a library of all paints sold here in NZ.
    The attitude we adopted here is spec a paint that you know will work. If you don’t know what paint it is and what the surface energy is like then do a simple test yourself. The test is either a tape snap test or a peel adhesion test using a electronic spring scale (what ya weigh fish with) and compare that to a library you set up of what you know are both high and low surface energies.
    Then we get into cure times but that’s for another discussion.
  12. Aragons
    Aragons New Member
    10
    Thanks for all the feed back- the paint is regular flat yellow from Walmart
    And the vinyl is Avery A6 should I repaint with enamel paint?
    I'm fairly new and all the info would help. Thanks
  13. Pat Whatley
    8,593
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Vinyl does not like to stick to flat paint. Go with a satin or semi-gloss and you should be okay.
  14. 4R Graphics
    4R Graphics Active Member
    724
    Use a satin, semi gloss or high gloss and ALWAYS use an oil based enamel. Never had a problem doing it with oil based enamel.
  15. Cross Signs
    Cross Signs Active Member
    548
    27
    28
    Mar 30, 2006
    Clearwater FL
    Sounds to me like a combination of problems and Avery is the first one! Use better vinyl
  16. Aragons
    Aragons New Member
    10
    What vinyl should i use?
  17. GP
    GP Very Active Member
    1,728
    Dec 12, 2007
    SC
    To keep this on track - anyone have a favorite paint?
  18. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Avery film and Walmart paint, Classic!
    Is this a joke? I hope so! First off, what kind of wood? OSB 4x8? MDO? I think this might be part of the problem.
    Let me guess, this was made on a cri-cut right?
    We use Ronan or Mathews paint, 3M or Oracal film. As far as putting it on wood, we don't anymore. We use aluminum, max-metal, PVC, lexan and coroplast for most of our production. Painting some old plyboard is what we did back in the 1980's.
  19. Si Allen
    Si Allen Very Active Member
    2,146
    1
    +1 for Mosh!
    :thumb:
  20. Pat Whatley
    8,593
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Sign #7 of the impending Apocalypse: Si agrees with Mosh.
