Jester1167
Can you explain your reasoning for slanting the #16 and not the #22? This one really boggles my balls.
And the different size (#) signs with one having an inline and one and outline.
Haha so one is to ever arch any word your saying that seems logical. There must be alot of sign people that feel ashamed right now. Even though I'm sure every single one of us has arched a lower case and upper case word. I guess i wasn't aware of the special arching font and case that was to be used. My bad.
What you don't seem to be aware of are the fundamental rules of typography. Break them at your peril and because you do understand them, not. as is your case, because you don't. When you say "every single one of us" you attempt to include yourself in a group of which, if this monstrosity is representative of your abilities, it's abundantly clear that you are not a member.
Anyone can make a mistake, only a damnfool insists on it.
I was trying to use the school colors as much as possible, As they asked for the red lettering. I put the black and gray outline on it. how's this?You never arch any text that is italic or script. That is one of the first rules of sign design. It makes for an unlegible mess as you can plainly see now. I know you don't want it to look like every other window sticker but there is a reason why those window stickers use the same type of text layout that Visual showed you...because it works.
I would not recommend red with a white outline either. Why not white with a red outline as it will actually look readable from 15 feet. The idea behind reinventing something is to improve it, which you have failed to do here.
I guess I could just print the maroon on some white IJ680CR that should do it for night time readability
I was trying to use the school colors as much as possible, As they asked for the red lettering. I put the black and gray outline on it. how's this? View attachment 92590 I guess I could just print the maroon on some white IJ680CR that should do it for night time readability
I am an Industrial Electrician and Refrigeration technician. Also custom automotive painting. I am new to computerized design using illustrator. But hey you got to start some where. Also I never said I had a art background.created designs....and you have a background in art or signs????
If it were not for questions this forum would not exist.
It would be tough for me to fix a frig to at least at first I work on R-717(Anhydrous Ammonia)refrigeration equipment. But once you ask questions then it all becomes clear on what to do. Remember some fool built everything around you some some fool will be able to fix it. None of us are smarter than the other, just some ask questions others keep quietmy guess is if I tried to fix a frig, I'd suck at it. that's what happens when you think someone else's job is easy and all you need is a tool to do it with. before going on with your "designing" you should invest some time learning the trade. I assume you didn't become an electrian or a refrigeration tech by posting a few questions on a site for people in those profession. yes everyone has to start somewhere but because you appear to be someone who has learned a trade, I would suggest learning this one too before jumping in
