Make sure you have enough negative space around the layout. If you're using stock premade banners and you have a 3'x4' banner, then the actual size after hemming is 33"x48' ( if you're using 3' material). You have a 1.5" hem all around the outside, so your actual imprint area is 30"x46.5". I usually start with this imprint size so I know that my design won't go into the hem area.
It's at His house! bahahah!
ok... Here they are side by side..
Jill's layout... And fredo's.
OK... here they are side by side..
Jill's layout... and Fredo's.
