My experience is that the liquid gets trapped in air egress material. We use glass cleaner if we have to wet apply against all the do gooders recommendations and have never had any failures. It's easier and faster dry, just hinge it in the middle. Grab an extra person to hold the vinyl while you squeegee if you cant on your own. Can you run it through your laminator?
Did you buy the prints or produce them yourself?
If you have a laminator, then its the best way to mount with the least amount of effort and best results. Using liquid on material with air egress like others have said, defeats the whole purpose. If you are worried about stretching of the image running it through your laminator, use transfer tape over the whole thing and it won't stretch.
If we hand mount prints that large, we use two people, a hinge about a third of the way in on the side we start with and the whole process takes but a few minutes.
I do have a laminator, and that is the way I would normally do it. I am just inquiring because I am concerned with the print stretching in the laminator. But I guess that's the way I will do it. Thanks.
Was I pissed? I don't usually walk around with a perma-smile.
I don't like the BS
At the beginning while you were murdering the plastic, you looked like some of my employees when I tell them to get off their phone.Was I pissed? I don't usually walk around with a perma-smile.
I don't like the BS
My answer is no. Since it has commandform, it would trap the liquid in and fail. Most printable vinyls you should only apply dry. Why would you want to wet apply it?
4' X 8's are extremely easy to lay down if you do it the proper way. Also some people do the dish soap route, but I won't, I use Rapid Tac for any wet apply application. I trust a professional product made for vinyl adhesive over trying to mix something myself and getting it wrong.
